Batch Adding Domain Names
If you want to host domain names registered with other DNS service providers on the DNS console, you can add these domain names in batches.
Generally, if your domain name is registered with Huawei Cloud, a public zone will be created automatically, and you can view the domain name on the DNS console.
- You can enter up to 10,000 domain names at a time.
- Only domain names that are not registered with Huawei Cloud can be added.
- If a public zone has been created for the domain name by another Huawei Cloud account, you can reclaim the public zone by referring to Reclaiming a Public Zone.
- Go to the Public Zones page.
- In the Batch Operations area above the public zone list, select Add Domain Names from the drop-down list.
Figure 1 Add Domain Names
- On the Add Domain Names tab, enter the domain names you want to add and select an enterprise project.
Figure 2 Batching add domain names
- Click Submit.
After domain names are added, you can view the operation name, result, time, and status on the View Batch Operations tab. You can also download failed operations.
