Updated on 2025-08-18 GMT+08:00
Intelligent Resolution Overview
Overview
Typically, a DNS server returns the same resolution result to visitors from different networks or geographical locations. However, in case of cross-network or cross-region access, this would lead to long latency and poor user experience.
With configurable resolution lines, you can specify that the DNS server return different resolution results for the same domain name based on the networks or geographical locations of visitors' IP addresses.
In addition to ISP and region lines, Huawei Cloud DNS allows you to customize resolution lines based on IP address ranges to route visitors to different web servers.
For a website deployed on multiple servers, you can set different weights for the record sets to balance the loads of these servers.
Where to Use
Table 1 describes the application scenarios of DNS Resolver.
Table 1 Application scenarios of DNS Resolver
Operation
Configuring ISP Lines for Record Sets
Configure ISP lines to distinguish visitors by carrier.
Configuring Region Lines for Record Sets
Configure region lines to distinguish visitors by geographical location.
Configuring Custom Lines
Configure custom lines to distinguish visitors by IP address range.
Configuring Weighted Routing
Configure weight-based resolution for load balancing based on the proportion of requests to each record set.
