Managing Private Zones
You can modify or delete private zones, or view their details.
Modifying a Private Zone
Enable or disable the recursive resolution proxy for subdomains, and update the description of a private zone.
- Go to the Private Zones page.
- Click
in the upper left corner and select the desired region and project. - Locate the private zone you want to modify and choose More > Modify in the Operation column.
- Modify the private zone.
- Click OK.
Deleting a Private Zone
Delete a private zone when you no longer need it. After a private zone is deleted, its record sets are also deleted.
Before you delete a private zone, back up all record sets in the private zone.
Locate the private zone you want to delete and choose More > Delete in the Operation column.
The Delete Private Zone dialog box is displayed.
- In the displayed dialog box, confirm the private zone to be deleted.
Deleting Private Zones
Delete multiple private zones at a time. After the private zones are deleted, domain names and their subdomains cannot be resolved by the DNS service.
Before you delete private zones, back up all record sets in the private zones.
- Select the private zones you want to delete and click Delete.
- In the displayed dialog box, confirm the private zones to be deleted.
Viewing Details About a Private Zone
View details about a private zone, such as the zone ID, time when the zone was created or modified, tag, and TTL, on the Private Zones page.
The latest modification time of a domain name cannot be updated until the record set is updated. This may cause inconsistency between the latest modification time of the record set and domain name.
- In the private zone list, view the domain name, status, associated VPCs, number of record sets, TTL, tags, time when the zone was created and when it was modified recently.
Disabling or Enabling a Private Zone
Disable a private zone to stop all record sets in the private zone. When you want to restore the resolution of the domain name, enable the private zone.
- Select the private zone you want to disable or enable and click Disable or Enable in the Operation column.
The Disable Private Zone or Enable Private Zone dialog box is displayed.
- Click OK.
Exporting Private Zones
You can export all or selected private zones to an XLSX file.
- In the upper part of the private zone list, click Export.
- Select the private zones to be exported:
- All private zones
- Only selected private zones
Figure 1 Exporting private zones
