Managing Public Zones
You can modify, export, enable, disable or delete public zones, or view their details.
Modifying a Public Zone
You can modify the description of a public zone.
- Go to the Public Zones page.
- Select the public zone you want to modify, and choose More > Modify in the Operation column.
The Modify Public Zone dialog box appears.
- Modify the public zone.
- Click OK.
Transferring a Public Zone
You can transfer a public zone including all its record sets from one account to another.
- Locate the public zone you want to transfer, choose More > Transfer in the Operation column.
The Transfer Public Zones tab appears.
- Enter the ID of the account that you want to transfer the domain name to.
- Click Submit.
Deleting a Public Zone
You can delete a public zone when you no longer need it.
After a public zone is deleted, the domain name and its subdomains cannot be resolved by the DNS service. Before you delete a public zone, back up all its record sets.
- Locate the public zone you want to delete and click More > Delete in the Operation column.
- In the displayed dialog box, confirm the public zone to be deleted.
Deleting Public Zones
You can delete multiple public zones at a time.
After the public zones are deleted, domain names and their subdomains cannot be resolved by the DNS service. Before you delete public zones, back up all the record sets.
Disabling or Enabling a Public Zone
You can disable a public zone to make all its record sets inactive. When you want to restore the resolution of the domain name, enable the public zone.
- Select the public zone you want to disable or enable and click Disable or Enable in the Operation column.
The Disable Public Zone or Enable Public Zone dialog box appears.
- Click OK.
Viewing Details About a Public Zone
On the Public Zones page, you can view details about public zones, including the domain name, status, DNS server address, number of record sets, enterprise project, tag, TTL, creation time, last modification time, and description.
The latest modification time of a domain name cannot be updated until the record set is updated. This may cause inconsistencies between the latest modification time of the record set and domain name.
- Go to the Overview page.
- On the Overview page, click Public Zones under My Resources.
Exporting Public Zones
You can export all or selected public zones to an XLSX file.
- In the upper part of the public zone list, click Export.
- Select the public zones to be exported:
- To export all public zones, click Export all data to an XLSX file.
- To export only selected public zones, click Export selected data to an XLSX file.
Figure 1 Exporting public zones
