Updated on 2025-07-30 GMT+08:00
Exporting Record Sets
If you want to transfer your domain name to another cloud service provider, you can export all the record sets configured for the domain name in batches. This feature is available for both public and private zones.
  • You can export the following information about a public zone record set: record set name, record set type, line type, TTL (s), weight, record set value, status, description, record set ID, time when the record set was created, and time when the record set was last modified.
  • You can export the following information about a private zone record set: record set name, record set type, TTL (s), record set value, status, description, record set ID, time when the record set was created, and time when the record set was last modified.
example.com is used as an example to describe how you can export all its record sets.
  1. Go to the DNS console.
  2. In the navigation pane on the left, choose Public Zones or Private Zones.
    The zone list is displayed.
  3. (Optional) If you have selected Private Zones, click on the upper left corner to select the region and project.
  4. In the zone list, click the domain name example.com.
  5. Click the Export and Import tab.
  6. Click Export Record Set.
    An .xlsx file named using the domain name is exported, for example, example.com.xlsx.
    In the exported file, you can view the following information about a record set (a public zone record set used as an example): record set name, record set type, line type, TTL (s), weight, record set value, status, description, record set ID, time when the record set was created, and time when the record set was last modified.
