Viewing the Retrieval Status
View the retrieval status, including the number of consumer instances, number of messages accumulated in the queue, retrieval model, retrieval rate, and consumer instance details.
Only the retrieval status of standard queues can be queried.
A queue and a consumer group have been created.
- Click
in the upper left corner of the management console and select a region.
Select the same region as your application service.
- Click Service List, and choose Application > Distributed Message Service to open the DMS console.
- In the navigation pane, choose Queue Manager.
- Click the name of a queue for which you want to view the retrieval status.
- On the queue details page, click the Consumer Groups tab.
- Choose More > View Retrieval Status in the same row as the chosen consumer group.
This feature is supported only by standard queues and not by advanced queues.
- Table 1 and Table 2 describe the retrieval status parameters.
Table 1 Retrieval status parameters Parameter
Consumer Group Name
Name of a consumer group.
Consumer Instances
Total number of consumer instances of a consumer group.
Messages Available
Number of consumable messages of a consumer group.
Total Retrieval TPS
Total retrieval rate of a consumer group.
Retrieval Model
Currently, only the multicast model is supported.
