User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Stacked Bar Chart
This section describes parameters of a stacked bar chart.
Figure 1 Stacked bar chart
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
- Global Style
- Font: text font.
- Series Spacing: spacing between chart series.
- Margin
- Top: spacing between the top sides of the chart and the component layer. You can enter a value or click
to adjust the spacing.
- Bottom: spacing between the bottom sides of the chart and the component. You can enter a value or click
- Left: spacing between the left sides of the chart and the component. You can enter a value or click
- Right: spacing between the right sides of the chart and the component. You can enter a value or click
- Value Tag
- Value Tag: to show or hide the value tag by clicking
or
- Font Size: font size of the value tag.
- Font Width: font width of the value tag.
- Color: font color of the value tag.
- Position: position of the value tag. The options are Top, Align right, Inside, Align left, Bottom, Inside left, Inside right, Inside top, and Inside bottom.
- X Axis
- X Axis: to show or hide the X axis by clicking
or
- Text: text style of the X axis, including Font Size, Color, Font Width, and Angle.
- Coordinate Axis: color of the X axis.
- Scale: to show or hide the scales by clicking
or
- Grid Line: grid line color of the X axis.
Figure 2 X axis of a stacked bar chart - X Axis: to show or hide the X axis by clicking
- Y Axis
- Y Axis: to show or hide the Y axis by clicking
or
- Text: text style of the Y axis, including Font Size, Color, Font Width, Angle, and Axis Label.
- Coordinate Axis: color of the Y axis.
- Grid Line: grid line color of the Y axis.
- Axis Unit: to set the unit and font color of the Y axis.
Figure 3 Y axis of a stacked bar chart - Y Axis: to show or hide the Y axis by clicking
- Legend
- Legend: to show or hide the legend by clicking
or
- Text: text style of the legend, including Font Size, Color, and Font Width.
- Spacing: distance between legends, including Left/Right Spacing and Top/Bottom Spacing.
Figure 4 Legends of a stacked bar chart - Legend: to show or hide the legend by clicking
- Message
- Message: If you click
, a message will pop up when you hover over a previewed or published component.
- Triggering Mode: to set the triggering mode of messages. The options are Coordinate Axis and Data.
- Color: font color of the message.
- Font Size: font size of the message.
- Font Width: font width of the message.
- Animation
- Click
or
next to Animation to hide or show animation, respectively.
- Duration: duration of the first rendering of the component, in ms.
- Animation Effect: The system provides multiple common animation slow-moving effects.
- Animate in Order: If this option is selected, the series are animated in sequence. If this option is deselected, all series are animated at the same time.
- Duration After Change: animation duration when the component data is updated, in ms.
- Start from Previous Position: If this option is selected, the animation is played from the position of the previous data when the component data is updated. If this option is deselected, the animation is played from the initial position when the component data is updated.
Figure 5 Animation (line chart) - Click
Data
For details about how to configure component data, see Configuring Component Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Bar Charts
