User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
Scanning Radar
This section describes parameters of a scanning radar chart.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Size and position of a scanning radar chart - Global Style
- Font: text font.
- Radius: to set the radius size by entering a value or dragging
- Value Tag: to set the text style, including Font Size, Color, and Font Width.
- Pole Axis
- Color: to set the color of the pole axes by clicking the color editor.
- Width: to set the width of the pole axes by entering a value or clicking
- Split Line
- Color: to set the color of the split lines by clicking the color editor.
- Lines: to set the number of the split lines by entering a value or clicking
- Line Style: to select a style for split lines from the drop-down list.
- Line Width: to set the width of the split lines by entering a value or clicking
- Fill Color
Color: to set the color of each area by clicking the color editor.
- Animation
- Color: to set the color of the scanning area by clicking the color editor.
- Play Duration: to set the play duration by entering a value or clicking
Data
For details about how to configure component data, see Configuring Component Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
