User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Radar Chart
This section describes parameters of a radar chart.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Size and position of a radar chart - Global Style
- Font: text font.
- Shape: shape of the image. The options are Circle and Polygon.
- Value Tag
- Value Tag: to show or hide value tags by clicking
or
- Font Size: font size of the label value.
- Color: font color of the tag value.
- Font Width: font width of the tag value.
- Angle Axis
- Text: to set the font size, color, and font width of the text.
- Rotation Angle: to set the rotation angle by entering a value or dragging
- Pole Axis
- Axis Label: to set the maximum and minimum values of the pole axis.
- Color: color of the pole axis.
- Width: width of the pole axis.
Figure 2 Polar axes of a radar chart - Split Line
- Color: color of the split line.
- Lines: to set the number of the split lines by entering a value or clicking
- Line Style: style of split lines. The options are Solid line, Dotted line, and Dash-dot line.
- Line Width: to set the width of the split lines by entering a value or clicking
Figure 3 Split lines of a radar chart - Legend
- Legend: to show or hide the legend by clicking
or
- Text: to set the font size, color, and width of the legend.
- Layout: to set the legend position, left/right spacing, top/bottom spacing, and inter-legend spacing.
- Message
- Message: If you click
, a message will pop up when you hover over a previewed or published component.
- Color: font color of the message.
- Font Size: font size of the message.
- Font Width: font width of the message.
- Animation
- Click
or
next to Animation to hide or show animation, respectively.
- Duration: duration of the first rendering of the component, in ms.
- Animation Effect: The system provides multiple common animation slow-moving effects.
- Duration After Change: animation duration when the component data is updated, in ms.
- Start from Previous Position: If this option is selected, the animation is played from the position of the previous data when the component data is updated. If this option is deselected, the animation is played from the initial position when the component data is updated.
- Click
Data
For details about how to configure component data, see Configuring Component Data.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Other Charts
