User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
On this page
Show all
Ticker Board
This section describes parameters of a ticker board.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Ticker board - Ticker Board
- Alignment: alignment mode of the ticker board. The value can be Align center, Left, or Right.
- Spacing: distance between the digits and the upper edge of the component.
- Animation: After this function is enabled, the number on the ticker board changes dynamically as the data changes.
- Animation Duration: set the duration for playing animation once by entering a value or clicking
. The unit is milliseconds.
- Trend: to show or hide Trend by clicking
or
. The value can be Up or Down. When the value in the subsequent validator is greater than the current value, the value increases. When the value in the subsequent flier is smaller than the current value, the trend is reduced. The trend icon is customizable.
- Prefix: to set the prefix content, font, font size, font color, and font width.
- Digit: to set the digit style, including the decimal control, font, size, color, width, spacing, horizontal padding, vertical padding, and background color.
- Suffix: to set the suffix content, font, size, color, and width.
Figure 2 Ticker board - Title
- Alignment: title alignment mode of the title. The value can be Top center, Top left, Top right, Bottom center, Bottom left, or Bottom right.
- Title Name: title name.
- Font: font of the title.
- Font Size: font size of the title.
- Color: font color of the title.
- Font Width: font width of the title.
Data
- name: name of the component title.
- If you set a name, the name that you have set is displayed.
- If you do not set a name, Title Name under Title on the Pattern tab page is displayed.
- If you do not set Title Name, no title is displayed.
- value: value displayed on a component.
- Data Source Type: to select the data source of the chart. Multiple data sources are provided for you to select. You need to add data sources first. For details, see Data Connection Overview.
- Converter: Select a converter to convert data into the data that meets the display requirements. For details, see Using a Converter.
- Automatic Update: If you select Automatic Update and set Update Interval, the data is automatically updated based on the interval.
- Preview Result: Click Preview Result to view the information about the selected data source. You can click Update Query to manually update the component data when the data source changes.
Interaction
For details about whether the component supports the interaction function and how to use the interaction function, see Configuring Component Interaction.
Parent topic: Text
