User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Show all
Tab Bookmark
This section describes the configuration items of the tab bookmark component.
Pattern
- Size/Position
- Size: width and height of the component. Unit: pixel.
- Position: position where the component is located in the canvas. Unit: pixel.
Figure 1 Tab Bookmark - Global Style
- Layout: layout of the tab bookmark. The value can be Crosswise or Lengthways.
- Alignment: title alignment mode of the tab bookmark. The value can be Top center, Top left, Top right, Bottom center, Bottom left, or Bottom right.
- Tab Slice Width: width of a tab slice.
- Tab Slice Height: height of a tab slice.
- Tab Slice Spacing: distance between tab slices.
- Initial Setting: initial tab slice value. The initial value must be the same as the value of id on the Data tab. For example, if the initial value is 1, the Tab1 column is highlighted.
- Font: font type of the component text.
- Preview Hidden: whether to hide the component during preview.
- Unselected Tab Style: background color, background image, text color, and font size of unselected tabs.
- Selected Style: background color, background image, text color, and font size of the selected tab.
- Animation: After this function is enabled, the tab pane dynamically changes with the specified animation duration.
- Tab Slice Config: Set the number and names of tabs. To add a tab, click
. To delete a tab, click
Data
This component does not have data events.
You can double-click the inside of a tab pane to add or remove other components to display different data. For details about how to use the added components, see the operation guide of the corresponding component.
Interaction
This component does not support interaction.
