User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
DLV provides various data sources. When using a screen, you can create data connections based on the data storage location. Data results will then display on the screen.
Log in to the DLV console and click the Data tab to manage data sources.
DLV supports the following types of data sources:
- APIs
- Databases
- Files
- Others
APIs
DLV supports API data sources.
DLV supports the following types of databases:
