User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Before establishing a data connection to a MySQL database, create a MySQL data connection first.
- You have obtained the IP address and port number of the MySQL data source, and the username and password for logging in to the MySQL database. In addition, you must have the SELECT permission on the database to be connected.
- You have used the CDM cluster as the network proxy or an Internet connection proxy to connect your screen to the MySQL data source network.
- If you use a CDM cluster, the following requirements must be met:
- You need to create a CDM cluster on the CDM console. The CDM cluster and DLV must be in the same region. For details about how to create a CDM cluster, see Creating a CDM Cluster.
- If the MySQL data source is not on Huawei Cloud, the host where the MySQL data source is located must have a public IP address, and the CDM cluster must be bound with an elastic IP address (EIP).
- If the MySQL data source is on Huawei Cloud, the host where the MySQL data source is located must be in the same region, AZ, and VPC as the CDM cluster.
- If the firewall is enabled on the host where the MySQL data source is located, the inbound and outbound rules of the firewall must allow the access of the MySQL database port and the CDM cluster address.
- The inbound and outbound rules of the security group to which the CDM cluster belongs must allow the access of the IP address and port of the MySQL database.
- If you use the Internet to connect to the data source, an EIP must be bound to the ECS where your MySQL database is deployed. The ECS and DLV must be in the same region and VPC, and can communicate with each other.
Creating a MySQL Data Connection
- Log in to the DLV console.
- On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
Figure 1 Creating a data connection
- In the New Data Connection dialog box, set Data Source Type to MySQL and set the related parameters.
Figure 2 Creating a MySQL data connection
Table 1 describes the MySQL data connection parameters.
Table 1 MySQL data connection parameters Parameter
Name
Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
Domain Name
IP address of the database. Private zones are not supported.
Port
Port of the database.
Username
Username of the database. The database user must have permission to access data tables and metadata.
Password
Password of the database user.
Agent
Select an available connection agent, such as VPC connection, CDM proxy, or Internet.
MySQL is not a fully managed service and thus cannot be directly connected to fully managed DLV. A CDM cluster serves as an agent that enables communication between them.
Database
You can select a database from the Database drop-down list.
- Click OK.
Using MySQL Data Sources
You can configure and use the MySQL data source by referring to the instructions in Using DWS Data Sources.
