Creating RDS for PostgreSQL Data Connections
Updated on 2024-06-21 GMT+08:00
Before establishing a data connection to RDS for PostgreSQL, ensure that the following conditions are met:
  • You have obtained the address, port number, username, and password of RDS for PostgreSQL.
  • A CDM cluster is available and used as the network agent to ensure that DLV can communicate with RDS for PostgreSQL.
Creating an RDS PostgreSQL Data Connection
  1. Log in to the DLV console.
  2. On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
    Figure 1 Creating a data connection
  3. In the New Data Connection dialog box, set Data Source Type to RDS for PostgreSQL and set the related parameters.
    Figure 2 Creating an RDS for PostgreSQL data connection
    Table 1 describes the RDS for PostgreSQL data connection parameters.
    Table 1 RDS for PostgreSQL data connection parameters
    Name
    Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
    Instance ID
    ID of the database instance.
    Domain Name
    After an instance ID is selected, an intranet IP address of a database is automatically matched. The domain name cannot be changed.
    Port
    After an instance ID is selected, a database port is automatically matched. The port cannot be changed.
    Username
    Username of the database. The database user must have permission to access data tables and metadata.
    Password
    Password of the database user.
    Agent
    RDS for PostgreSQL is not a fully managed service and thus cannot be directly connected to fully managed DLV. A CDM cluster serves as an agent that enables communication between them.
    Database
    You can select a database from the Database drop-down list.
  4. Click OK.
Using RDS for PostgreSQL Data Sources
You can configure and use RDS for PostgreSQL data sources by referring to the instructions in Using DWS Data Sources.
