User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Before establishing a data connection to MapReduce (MRS) Hive, ensure that the following conditions are met:
- An MRS cluster earlier than 2.0.0 has been created. The cluster contains Hive components. Kerberos authentication has been disabled for the MRS cluster. DLV does not support MRS Hive data sources with Kerberos authentication enabled.
- You have obtained the MRS Hive address.
- A CDM cluster is used as the network agent to ensure that DLV can communicate with MRS. Ensure that an available CDM cluster exists and is in the same region, AZ, and VPC as the MRS data source. In addition, the CDM cluster and MRS data source must be in the same security group or the security group rule allows them to communicate with each other.
In CDM, you only need to do nothing but create a CDM cluster.
Creating an MRS Hive Data Connection
- Log in to the DLV console.
- On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
Figure 1 Creating a data connection
- In the New Data Connection dialog box, set Data Source Type to MRS Hive and set the related parameters.
Figure 2 Creating an MRS Hive data connection
Table 1 MRS Hive data connection parameters Parameter
Name
Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
Cluster Name
Name of the MRS cluster.
Domain Name
After an MRS cluster is selected, the preferred private IP address of the cluster will be automatically matched. The domain name cannot be changed.
Agent
Select an available connection agent, such as VPC connection, CDM proxy, or Internet.
MRS Hive is not a fully managed service and thus cannot be directly connected to fully managed DLV. A CDM cluster serves as an agent that enables communication between them.
Database
You can select a database from the Database drop-down list.
- Click OK.
Using MRS Hive Data Sources
You can configure and use MRS Hive data sources by referring to the instructions in Using DWS Data Sources.
