User Guide
- Preparatory Work
- Introducing the DLV Console
- How-Tos
- Managing Workspaces
- Creating Data Connections
- Creating Screens
- Developing Screens
- Managing Screens
- Managing Layers
Data Connection Management
- Data Connection Overview
- Using Static Data Sources
- Creating API Data Connections
- Creating CSV File Data Connections
- Creating Object Storage Service Data Connections
- Creating Data Warehouse Service Data Connections
- Creating Data Lake Insight Data Connections
- Creating MRS Hive Data Connections
- Creating MRS SparkSQL Data Connections
- Creating ClickHouse Data Connections
- Creating RDS for MySQL Data Connections
- Creating RDS for PostgreSQL Data Connections
- Creating RDS for SQL Server Data Connections
- Creating RDS for GaussDB Data Connections
- Creating GeminiDB Influx API Data Connections
- Creating Cloud Search Service Data Connections
- Creating DDM Data Connections
- Creating Oracle Data Connections
- Creating MySQL Data Connections
- Creating PostgreSQL Data Connections
- Creating SQL Server Data Connections
- Creating Elasticsearch Data Connections
- Editing Data Connections
- Searching for Data Connections
- Deleting Data Connections
- Managing Components
- Component Guide
- Screen Combination
- Integrating DLV into Third-Party Systems
- Change History
- Developer Guide
- API Reference
- What Is DLV Used For?
- Regions and AZs
- Can I Quickly Create a DLV Screen Using a Template?
- Can DLV Connect to Data Sources Through APIs?
- What Types of Data Connections Are Supported in DLV?
- How Do I Configure a CSV Data Source?
- How Do I Use the Interaction Function?
- What Can I Do If a Component Cannot Be Completely or Normally Displayed?
- How Do I Query Data Formats Supported by Different Components?
- What Can I Do When the WebGL Component Breaks Down?
More Documents
- Preparatory Work
- How-Tos
- Creating Screens
- Managing Screens
- Managing Layers
- Creating API Gateway Data Connections
- Creating a DAYU Data Connection
- Managing VPC Connections
- Component Guide
- What Is DLV?
- Regions and AZs
- How Many Screens Can I Create in DLV?
- API Reference (ME-Abu Dhabi Region)
- Developer Guide (ME-Abu Dhabi Region)
Source data required for screen creation can be static data or non-static data.
- Static data: You can enter and use static data on the screen development page.
- Non-static data: Non-static data is stored locally or in other cloud services.
Assume that user data is stored in Data Warehouse Service (DWS). The following section describes how to establish a data connection between DLV and DWS on the Data page. After the data connection is successfully created, DLV can use data in DWS.
For details about more data sources, see Creating Data Connections.
- You have obtained the IP address, port number, username, and password of DWS.
- A Cloud Data Migration (CDM) cluster is used as the network agent to ensure that DLV can communicate with DWS. Ensure that an available CDM cluster exists and is in the same region, AZ, and VPC as the DWS data source. In addition, the CDM cluster and DWS data source must be in the same security group or the security group rule allows them to communicate with each other.
In CDM, you only need to do nothing but create a CDM cluster.
Creating a Data Connection
- Log in to the DLV console.
- In the navigation pane on the left, click Data.
- On the Data page, click the workspace drop-down list at the top of the page, select the workspace to be accessed, and click New Data Connection.
Figure 1 Creating a data connection
- In the data source list, choose Data Warehouse Service. Specify the related parameters. For details about how to create a data connection, see Data Connection Overview.
For example, if Data Source Type is set to Data Warehouse Service, configure the data source parameters by referring to Table 1.
Figure 2 Configuring the data sourceTable 1 DWS data connection parameters Parameter
Name
Name of the data connection. Must contain 1 to 32 characters and contain only letters, digits, hyphens (-), and underscores (_).
Cluster Name
Name of the DWS cluster. To create a DWS cluster, click Create Cluster next to the drop-down list.
Domain Name
After a DWS cluster is selected, an intranet domain name of a database will be automatically matched. The domain name is alterable.
Port
After a DWS cluster is selected, a database port will be automatically matched. The port is alterable.
Username
Username of the database. The database user must have permission to access data tables and metadata.
Password
Password of the database user.
Agent
Name of the CDM cluster. To view all available CDM clusters, click View Agent next to the drop-down list.
DWS is not a fully managed service and thus cannot be directly connected to fully managed DLV. A CDM cluster serves as an agent that enables communication between them.
Database
You can select a database from the Database drop-down list.
If there is no database displayed, check whether the database username and password are correct. Then, ensure that security group rules have been configured to allow database connections. Ensure that the CDM proxy and the DB instance are in the same VPC. If the fault persists, contact technical support.
Currently, DLV cannot use CDM 2.9 or later as a proxy.
- Click OK.
