On this page
Import GES
Function
The Import GES node is used to import files from an OBS bucket to a GES graph.
Parameters
Table 1 and Table 2 describe the parameters of the Import GES node.
Table 1 Parameters of Import GES nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Graph Name
Yes
Select the graph to be imported.
To create a GES graph, go to the GES console.
Metadata
Yes
Select the corresponding metadata.
Edge Dataset
Yes
Select the corresponding edge dataset.
Vertex Dataset
No
Select the corresponding vertex dataset. If it is not selected, the vertices in the edge dataset are used as the source of the vertex dataset.
Edge Processing
Yes
The edge processing supports the following modes:
  • Allow repetitive edges
  • Ignore subsequent repetitive edges
  • Overwrite previous repetitive edges
Offline
No
Indicates whether offline import is selected. The value is true or false, and the default value is false.
  • true: Offline import is selected. The import speed is high, but the graph is locked and cannot be read or written during the import.
  • false: Online import is selected. Compared with offline import, online import is slower. However, the graph can be read (cannot be written) during the import.
Ignore Labels on Repetitive Edges
No
Indicates whether to ignore labels on repetitive edges. The value is true or false, and the default value is true.
  • true: Indicates that the repetitive edge definition does not contain the label. That is, the <source vertex, target vertex> indicates an edge, excluding the label information.
  • false: Indicates that the repetitive edge definition contains the label. That is, the <source vertex, target vertex, label> indicates an edge.
Log Storage Path
No
Stores vertex and edge datasets that do not comply with the metadata definition, as well as detailed logs generated during graph import.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
