Developing a Hive SQL Script
This section introduces how to develop a Hive SQL script on Data Development.
Scenario Description
As a one-stop big data development platform, Data Development supports development of multiple big data tools. Hive is a data warehouse tool running on Hadoop. It can map structured data files to a database table and provides a simple SQL search function that converts SQL statements into MapReduce tasks.
Preparations
- MapReduce Service (MRS) has been enabled and the MRS cluster MRS_1009 has been created for providing an operating environment for Hive SQL.
When creating an MRS cluster, note the following:
- Kerberos authentication is disabled for the cluster.
- Hive is available.
- Cloud Data Migration (CDM) has been enabled and the CDM cluster cdm-7357 has been created for providing a proxy for communication between Data Development and MRS.
When creating a CDM cluster, note the following:
- The virtual private cloud (VPC), subnet, and security group can communicate with the MRS cluster MRS_1009.
Creating a Hive Data Connection
Before developing a Hive SQL script, create a connection to MRS Hive on Data Development. In this example, the data connection is named hive1009.
Description of key parameters:
- Cluster Name: Name of the MRS cluster created in MapReduce Preparations.
- CDM Cluster: Name of the CDM cluster created in CDM Preparations.
Create a Hive SQL script named hive_sql on Data Development. Then enter SQL statements in the editor to fulfill business requirements.
Notes:
- The script development area in Figure 2 is a temporary debugging area. After you close the tab page, the development area will be cleared. Click
to save the script to a specified directory. - Data Connection: Connection created in Creating a Hive Data Connection.
Developing a Hive SQL Job
After the Hive SQL script is developed, build a periodically deducted job for the Hive SQL script so that the script can be executed periodically.
- Create an empty Data Development job named job_hive_sql. Figure 3 Creating a job named job_hive_sql
- Go to the job development page, drag the MRS Hive SQL node to the canvas, and click the node to configure node properties. Figure 4 Configuring properties for an MRS Hive SQL node
Description of key properties:
- SQL Script: Hive SQL script hive_sql that is developed in Developing a Hive SQL Script.
- Data Connection: Data connection that is configured in the SQL script hive_sql is selected by default. The value can be changed.
- Database: Database that is configured in the SQL script hive_sql and is selected by default. The value can be changed.
- Node Name: Name of the SQL script hive_sql by default. The value can be changed.
- After the job orchestration is complete, click
to test the job. - If logs do not record any errors, click the blank area on the canvas and configure the job scheduling policy on the scheduling configuration page on the right. Figure 5 Configuring the scheduling mode
Note:
- 2018/10/11 to 2018/11/10: The job is executed at 02:00 a.m. every day.
- Click
to save the job and click
to schedule the job to enable the job to run automatically every day.
