- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
Loop Embedded Objects
You can use Loop embedded objects to obtain data from the For Each dataset.
Property
Property |
Type |
Description |
dataArray |
String |
Dataset input by the For Each node. It is a two-dimensional array. |
current |
String |
Data row traversed by the For Each node. It is a one-dimensional array. |
offset |
Int |
Current offset of the For Each node, starting from 0. Loop.dataArray[Loop.offset] = Loop.current. |
