- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
JSONUtil Embedded Objects
A JSONUtil embedded object provides JSON object methods.
Methods
Method |
Description |
Object parse(String jsonStr) |
Converts a JSON character string into an object. |
String toString(Object jsonObject) |
Converts an object to a JSON character string. |
Object path(String jsonStr,String jsonPath) |
Returns the field value in a path specified by the JSON character string. This method is similar to XPath and can be used to retrieve or set JSON by path. You can use . or [] in the path to access members and values. For example, tables[0].table_name. |
Example
The content of variable str is as follows:
{ "cities": [{ "name": "Shenzhen", "areaCode": "0755" }, { "name": "city2", "areaCode": "010" }, { "name": "Shanghai", "areaCode": "021" }] }
The expression for obtaining the area code of Shenzhen is as follows:
#{JSONUtil.path(str,"cities[0].areaCode")}
