- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
Basic Operators
EL supports most of the arithmetic and logic operators provided by Java.
Operator List
Operator |
Description |
Accesses a Bean property or a mapping entry. |
Accesses an array or linked list. |
Organizes a subexpression to change priority. |
Plus sign |
Minus or negative sign |
Multiplication sign |
/ or div |
Division sign |
% or mod |
Modulo |
== or eq |
Test whether equal to. |
!= or ne |
Test whether unequal to. |
< or lt |
Test whether less than. |
> or gt |
Test whether greater than. |
<= or le |
Check whether less than or equal to. |
>= or ge |
Test whether greater than or equal to. |
&& or and |
Test logic and. |
|| or or |
Test logic or. |
! or not |
Test negation. |
empty |
Test whether empty. |
The expression is similar to if else. If the statement in front of ? is true, the value of the expression between ? and : is returned. Otherwise, the value following : is returned. |
Example
If variable a is empty, default is returned. If variable a is not empty, a itself is returned. The expression is as follows:
#{empty a?"default":a}
