- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Expression Overview
Node parameter values in a Data Development job can be dynamically generated based on the running environment by using Expression Language (EL). EL uses simple arithmetic and logic to calculate and references embedded objects, including job objects and tool objects.
Job object: provides properties and methods of obtaining the output message, job scheduling plan time, and job execution time of the previous node in a job.
Tool job: Provides methods of operating character strings, time, and JSON. For example, truncating a substring from a string or formatting time.
Syntax
Expression syntax:
#{expr}
In the preceding information, expr indicates an expression. # and {} are common operators used in EL, allowing you to access job properties using embedded objects.
Example
In the URL parameter of the Rest Client node, use expression tableName=#{JSONUtil.path(Job.getNodeOutput("get_cluster"),"tables[0].table_name")}, as shown in Figure 1.
Expression description:
- Job.getNodeOutput("get_cluster") is used to obtain the execution result of the get_cluster node in the job. The execution result is a JSON character string.
- tables[0].table_name is used to obtain the value of a field in the JSON character string.
