Help Center/
Data Lake Factory/
User Guide/
Data Development/
Script Development/
Exporting and Importing a Script
Exporting a Script
You can export one or more script files from the script directory.
- Click
in the script directory and select Show Check Box.
Figure 1 Clicking Show Check Box
- Select the scripts to be exported, click
, and choose Export Script.
Figure 2 Selecting and exporting scripts
Importing a Script
You can import one or more script files in the script directory.
- Click
and choose Import Script in the script directory, select the script file that has been uploaded to OBS, and set Duplicate Name Policy.
Figure 3 Importing a Script
- Click Next.
Parent topic: Script Development
