- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
Copying a Script
This section describes how to copy a script.
The script file to be copied exists in the script directory.
- Log in to the DLF console.
- In the navigation tree of the DLF console, choose Development > Develop Script.
- In the script directory, select the script to be copied, right-click the script name, and choose Copy Save As.
- In the displayed dialog box, configure related parameters. Table 1 describes the parameters.
Table 1 Script directory parameters Parameter
Script Name
Name of the script. It contains a maximum of 128 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
The name of the copied script cannot be the same as the name of the original script.
Select Directory
Parent directory of the script directory. The parent directory is the root directory by default.
- Click OK.
