On this page
Open/Close Resource
Functions
The Open/Close Resource node is used to enable or disable the HUAWEI CLOUD service.
Parameters
Table 1 and Table 2 describe the parameters of the Open/Close Resource node.
Table 1 Parameters of Open/Close Resource nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Service
Yes
Service to be opened or closed.
  • ECS
  • CDM
  • CS
Open/Close Resource
Yes
Possible values:
  • On
  • Off
Instance
Yes
Object to be opened or closed, for example, to open a CDM cluster.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
