On this page
DLI Spark
Functions
The DLI Spark node is used to execute a predefined Spark job.
Parameters
Table 1 and Table 2 describe the parameters of the DLI Spark node.
Table 1 Parameters of DLI Spark nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
DLI Queue
Yes
Select a queue from the drop-down list box.
Job Name
Yes
Name of the DLI Spark job. It must consist of 1 to 64 characters and contain only letters, digits, and underscores (_). The default value is the same as the node name.
Job Running Resources
No
Select the running resource specifications of the job.
  • 8-core, 32 GB memory
  • 16-core, 64 GB memory
  • 32-core, 128 GB memory
Major Job Class
Yes
Main class of the DLI Spark job, that is, the main class of the JAR package.
Spark program resource package
Yes
JAR package of the user-defined Spark application. Before selecting a resource package, you need to upload the JAR package and its dependency packages to the OBS bucket and create resources on the resource management page. For details, see Creating a Resource.
Major-Class Entry Parameters
No
Enter the entry parameters of the program. Press Enter to separate the parameters.
Spark Job Running Parameters
No
Enter a parameter in the format of key/value. Press Enter to separate multiple key-value pairs. For details about the parameters, see Spark Configuration.
Module Name
No
Dependency modules provided by DLI for executing datasource connection jobs. To access different services, you need to select different modules.
  • CloudTable/MRS HBase: sys.datasource.hbase
  • CloudTable/MRS OpenTSDB: sys.datasource.opentsdb
  • RDS MySQL: sys.datasource.rds
  • RDS PostGre: sys.datasource.rds
  • DWS: sys.datasource.dws
  • CSS: sys.datasource.css
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
