Rest Client
Functions
The Rest Client node is used to respond to RESTful requests in HUAWEI CLOUD. Only the RESTful requests that have been authenticated by IAM Token are supported.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the Rest Client node.
Parameter |
Mandatory |
Description |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
Retry upon Failure |
Yes |
Indicates whether to re-execute a node task if its execution fails. Possible values:
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
Failure Policy |
Yes |
Operation that will be performed if the node task fails to be executed. Possible values:
Parameter |
Description |
Input |
Add |
Click Add. In the Type drop-down list, select the type to be created. The value can be DLI, DWS, OBS, or CSS.
OK |
Click OK to save the parameter settings. |
Cancel |
Click Cancel to cancel the parameter settings. |
Edit |
Click |
Delete |
Click |
View Details |
Click |
Output |
Add |
OK |
Cancel |
Edit |
Click |
Delete |
Click |
Table Details |
Click |
