- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
MRS Spark
Functions
The MRS Spark node is used to execute a predefined Spark job on MRS.
Parameters
Table 1 and Table 2 describe the parameters of the MRS Spark node.
Parameter |
Mandatory |
Description |
Node Name |
Yes |
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
MRS Cluster Name |
Yes |
Name of the MRS cluster.
To create an MRS cluster, use either of the following methods:
Spark Job Name |
Yes |
Name of the MRS job. Must consist of 1 to 64 characters and contain only letters, digits, and underscores (_). |
JAR Package |
Yes |
Select a JAR package. Before selecting a JAR package, you need to upload the JAR package to the OBS bucket, create a resource on the Resource Management page, and add the JAR package to the resource management list. For details, see Creating a Resource. |
JAR File Parameters |
No |
Parameters of the JAR package. |
Program Parameter |
No |
Used to configure optimization parameters such as threads, memory, and vCPUs for the job to optimize resource usage and improve job execution performance. This parameter is mandatory if the cluster version is MRS 1.8.7 or later than MRS 2.0.1. For details about the program parameters of MRS Spark jobs, see Running a Spark Job in the MapReduce User Guide. |
Input Data Path |
No |
Path where the input data resides. |
Output Data Path |
No |
Path where the output data resides. |
Parameter |
Mandatory |
Description |
Node Status Polling Interval (s) |
Yes |
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
Retry upon Failure |
Yes |
Indicates whether to re-execute a node task if its execution fails. Possible values:
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
Failure Policy |
Yes |
Operation that will be performed if the node task fails to be executed. Possible values:
