On this page
MRS MapReduce
Functions
The MRS MapReduce node is used to execute a predefined MapReduce program on MRS.
Parameters
Table 1 and Table 2 describe the parameters of the MRS MapReduce node.
Table 1 Parameters of MRS MapReduce nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
MRS Cluster Name
Yes
Name of the MRS cluster.
To create an MRS cluster, use either of the following methods:
  • Click . On the Clusters page, create an MRS cluster.
  • Go to the MRS console to create an MRS cluster.
MapReduce Job Name
Yes
Name of the MRS job. Must consist of 1 to 64 characters and contain only letters, digits, and underscores (_).
JAR Package
Yes
Select a JAR package. Before selecting a JAR package, you need to upload the JAR package to the OBS bucket, create a resource on the Resource Management page, and add the JAR package to the resource management list. For details, see Creating a Resource.
JAR File Parameters
No
Parameters of the JAR package.
Input Data Path
No
Path where the input data resides.
Output Data Path
No
Path where the output data resides.
Table 2 Advanced parameters
Mandatory
Node Status Polling Interval (s)
Yes
Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds.
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
