CSS
Functions
The CSS node is used to process CSS requests and enable online distributed searching.
Parameters
Table 1 and Table 2 describe the parameters of the CSS node.
| Parameter | Mandatory | Description |
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| CloudSearch Cluster | Yes | Connection to CloudSearch. A CloudSearch cluster has been created in CloudService. Currently, only clusters of version 5.5.1 is supported. |
| CDM Cluster Name | Yes | A CDM cluster. The Agent provided by the CDM cluster is the operating environment of CSS. If there are no CDM clusters available in the drop-down list, create one on the CDM console. |
| Request Type | Yes | Possible values:
| Request Parameter | No | Parameter of the request. For example, to query the dlfdata mapping type in the dlf_search index, set this parameter to: /dlf_search/dlfdata/_search |
| Request Body | No | The request body is in JSON format. |
| CloudSearch Output Path | No | Path where output data is to be stored. |
| Node Status Polling Interval (s) | Yes | Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
