CDM Job
Functions
The CDM Job node is used to execute a predefined CDM job for data migration.
Parameters
Table 1, Table 2, and Table 3 describe the parameters of the CDM Job node. Configure the lineage to identify the data flow direction, which can be viewed in the data asset module.
| Parameter | Mandatory | Description |
| CDM Cluster Name | Yes | Name of the CDM cluster to which the CDM job to be executed belongs. |
| CDM Job Name | Yes | Name of the CDM job to be executed. |
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| Node Status Polling Interval (s) | Yes | Specifies how often the system check completeness of the node task. The value ranges from 1 to 60 seconds. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
| Parameter | Description |
| Input | |
| Add | Click Add. In the Type drop-down list, select the type to be created. The value can be DLI, DWS, OBS, or CSS.
| OK | Click OK to save the parameter settings. |
| Cancel | Click Cancel to cancel the parameter settings. |
| Edit | Click |
| Delete | Click |
| View Details | Click |
| Output | |
| Edit | Click |
| Delete | Click |
| Table Details | Click |
