- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Managing a Notification
You can configure DLF to notify you of job success after it is performed.
Configuring a Notification
Before configuring a notification, ensure that Simple Message Notification (SMN) has been enabled, a topic has been configured in SMN, and a job has been submitted and is not in the Not Started state.
- Log in to the DLF console.
- In the navigation tree of the Data Development console, choose Monitoring > Manage Notification.
- On the Notification Management tab page, click Configure Notification. In the displayed dialog box, configure parameters. Table 1 describes the parameters.
Table 1 Notification parameters Parameter
Mandatory
Job Name
Yes
Name of the job.
Notification Mode
Yes
Select a notification mode:
- Voice
- Topic Message
Notification Type
Yes
Type of the notification.
- Run abnormally/Fail: When a job cannot run normally or fail to run, a notification is sent to notify the user of the abnormality.
- Run successfully: When a job runs successfully, a notification is sent to notify the user of the success.
- Uncompleted: This function supports only the jobs scheduled by day. If the job execution time is later than the configured time by which the job has not finished, a notification is sent.
For a real-time job, a notification is allowed to be sent only when the real-time job is in the Run abnormally or Failed state. For a batch job, a notification can be sent no matter when the batch job is in the Run normally, Run abnormally, or Failed state.
Topic for Abnormal/Failed Running
Yes
Select a topic for abnormal job running or job failure.
Topic for Successful Running
Yes
Select a topic for successful job running.
Notification
Yes
Specifies whether to enable the notification function. The function is enabled by default.
- Click OK.
DLF sends notifications through the Simple Message Notification (SMN). Using SMN may incur fees. For price details, contact the SMN support personnel.
Editing a Notification
After a notification is created, you can modify the notification parameters as required.
- Click the Notification Management tab.
- In the Operation column of a notification, click Edit. In the displayed dialog box, edit notification parameters. Table 1 describes the notification parameters.
- Click Yes.
Disabling the Notification Function
You can disable the notification function on the Edit Notification page or in the notification list.
- In the Notification Function column, click
. When it changes to
, the notification function is disabled.
Viewing a Notification
You can view all notification information on the Notification Records tab page.
- Click the Notification Records tab.
Deleting a Notification
If you do not need to use a notification any more, perform the following operations to delete it:
- In the Operation column of the notification, click Delete. The Delete Notification dialog box is displayed.
- Click OK.
