Help Center/ Data Lake Factory/ User Guide/ Data Management/ Database Schemas/ Deleting a Database Schema
If you do not need to use a database schema any more, perform the following operations to delete it.
The default database schema cannot be deleted.
- Log in to the DLF console.
- In the navigation tree of the Data Development console, choose /.
- In the menu on the left, click
, right-click the database schema that you want to delete, and choose Delete from the shortcut menu. - In the displayed dialog box, click OK.
Parent topic: Database Schemas
