On this page
MRS Kafka
Functions
The MRS Kafka node is used to query the number of messages that are not consumed by a topic.
Parameters
Table 1 and Table 2 describe the parameters of the MRS Kafka node.
Table 1 Parameters of MRS Kafka nodes
Mandatory
Data Connection
Yes
Select the MRS Kafka connection created in the management center.
Topic Name
Yes
Select a topic that has been created in MRS Kafka. The SDK or command line can be used to create a topic.
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Table 2 Advanced parameters
Mandatory
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
