- What's New
User Guide
- Preparations
- IAM Permissions Management
- Data Management
- Data Integration
- Data Development
- Solution
- O&M and Scheduling
- Configuration and Management
- Specifications
- Usage Tutorials
References
Nodes
- Node Overview
- CDM Job
- DIS Stream
- DIS Dump
- DIS Client
- Rest Client
- Import GES
- MRS Kafka
- Kafka Client
- CS Job
- DLI SQL
- DLI Spark
- DWS SQL
- MRS SparkSQL
- MRS Hive SQL
- MRS Presto SQL
- MRS Spark
- MRS Spark Python
- MRS Flink Job
- MRS MapReduce
- CSS
- Shell
- RDS SQL
- ETL Job
- OCR
- Create OBS
- Delete OBS
- OBS Manager
- Open/Close Resource
- Data Quality Monitor
- Subjob
- SMN
- Dummy
- For Each
- EL
Nodes
- Change History
- API Reference
- What Is DLF?
- What Is DLF Used For?
- What Is a Job?
- How Many Jobs Can Be Created in DLF?
- Can I Adjust the Job Quota in DLF?
- Does DLF Provide Job Templates?
- What Is a Node?
- Is There a Limit on the Number of Nodes Contained in a DLF Job?
- How Can I Quickly Rectify a Deleted CDM Cluster Associated with a Job?
- What Causes a Large Difference Between the Plan Time and Start Time of a Job?
- How Do I Change the Message Language?
- What Can I Do When a Job Fails?
- Glossary
Show all
DIS Client
Functions
The DIS Client node is used to send messages to a DIS stream.
Parameters
Table 1 describes the parameters of the DIS Client node.
Parameter |
Mandatory |
Description |
Using DIS Connection |
No |
If this function is enabled, messages can be sent to the DIS streams of another account. If this function is not enabled, messages can be sent only to the DIS streams in all regions of the current account. |
DIS Connection |
No |
Select a created DIS connection. |
Region |
No |
Region that the target DIS stream belongs to. The DIS Client node is used to send messages to the target DIS stream. |
Node Name |
Yes |
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
Stream Name |
Yes |
DIS stream to which messages will be sent. You can select a DIS stream by entering the DIS stream address or clicking |
Sent Data |
Yes |
Text sent to the DIS stream. You can directly enter text or click |
Related Job |
No |
Click A maximum of 10 jobs can be selected. After selecting a job, click Monitor. On the Monitory Job page, select the DIS Client node and click View Related Job on the lower part of the page. In the View Related Job dialog box, click View in the Operation column of a job to view the details about the job. |
Parameter |
Mandatory |
Description |
Max. Node Execution Duration |
Yes |
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
Retry upon Failure |
Yes |
Indicates whether to re-execute a node task if its execution fails. Possible values:
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
Failure Policy |
Yes |
Operation that will be performed if the node task fails to be executed. Possible values:
