On this page
OCR
Functions
The OCR node is used to recognize text on images and store the recognition result in a specified OBS directory.
The OCR node can be used only in CN North-Beijing4.
Parameters
Table 1 and Table 2 describe the parameters of the OCR node.
Table 1 Parameters of OCR nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
Image Path
Yes
OBS path of the image to be recognized.
Category
Yes
Image type that can be recognized. Currently, only General Text OCR is supported. It can be used in various scenarios, such as scanned files, electronic documents, books, documents, and forms.
Storage Directory
Yes
OBS directory for storing the recognition result.
Table 2 Advanced parameters
Mandatory
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
