MRS Spark Python
Functions
The MRS Spark Python node is used to execute a predefined Spark Python job on MRS.
Parameters
Table 1 and Table 2 describe the parameters of the MRS Spark Python node.
| Parameter | Mandatory | Description |
| Node Name | Yes | Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>). |
| MRS Cluster Name | Yes | Select an MRS cluster that supports Spark Python. Only a specific version of MRS supports Spark Python. Test the cluster first to ensure that it supports Spark Python. To create an MRS cluster, use either of the following methods:
For details about how to create an MRS cluster, see Custom Purchase of a Cluster in MapReduce User Guide. |
| Job Name | Yes | Name of the MRS Spark Python job. It must consist of 1 to 64 characters and contain only letters, digits, and underscores (_). |
| Parameter | Yes | Enter the parameters of the executable program of MRS. Use Enter to separate multiple parameters. |
| Attribute | No | Enter parameters in the key=value format. Use Enter to separate multiple parameters. |
| Max. Node Execution Duration | Yes | Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state. |
| Retry upon Failure | Yes | Indicates whether to re-execute a node task if its execution fails. Possible values:
NOTE: If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state. |
| Failure Policy | Yes | Operation that will be performed if the node task fails to be executed. Possible values:
