On this page
ETL Job
Functions
The ETL Job node is used to extract data from a specified data source, preprocess the data, and import the data to the target data source.
Parameters
Table 1 and Table 2 describe the parameters of the ETL Job node.
Table 1 Parameters of Transform Load nodes
Mandatory
Node Name
Yes
Name of the node. Must consist of 1 to 128 characters and contain only letters, digits, underscores (_), hyphens (-), slashes (/), less-than signs (<), and greater-than signs (>).
ETL Configuration
Yes
Click to edit the source and destination data to be transformed.
The supported source data types are DLI, OBS, and MySQL.
  • When the source data type is DLI, the supported destination data types are DWS, GES, CSS, OBS, and DLI.
  • When the source data type is MySQL, the supported destination data type is MySQL.
  • When the source data type is OBS, the supported destination data types are DLI and DWS.
NOTICE:
  • Data transformation from DLI to DWS:
    Before importing data from DLI to DWS, ensure that a DWS data connection has been created on DLF and a DWS table have been created on DWS.
  • Data transformation from DLI to CSS:
    Before importing data from DLI to CSS, ensure that a cross-source connection associated with CSS has been created on DLI. For details about how to create a cross-source connection on DLI, see Data Lake Insight User Guide.
Configure SQL Template
No
Click Obtain Template to obtain an SQL template.
Table 2 Advanced parameters
Mandatory
Max. Node Execution Duration
Yes
Execution timeout interval for the node. If retry is configured and the execution is not complete within the timeout interval, the node will not be retried and is set to the failed state.
Retry upon Failure
Yes
Indicates whether to re-execute a node task if its execution fails. Possible values:
  • Yes: The node task will be re-executed, and the following parameters must be configured:
    • Maximum Retries
    • Retry Interval (seconds)
  • No: The node task will not be re-executed. This is the default setting.
If Timeout Interval is configured for the node, the node will not be executed again after the execution times out. Instead, the node is set to the failure state.
Failure Policy
Yes
Operation that will be performed if the node task fails to be executed. Possible values:
  • End the current job execution plan
  • Go to the next job
  • Suspend the current job execution plan
  • Suspend execution plans of the current and subsequent nodes
Table 3 Lineage
Input
Add
Click Add. In the Type drop-down list, select the type to be created. The value can be DLI, DWS, OBS, or CSS.
  • DWS
    • Connection Name: Click . In the displayed dialog box, select a DWS data connection.
    • Database: Click . In the displayed dialog box, select a DWS database.
    • Schema: Click . In the displayed dialog box, select a DWS schema.
    • Table Name: Click . In the displayed dialog box, select a DWS table.
  • OBS
    • Path: Click . In the displayed dialog box, select an OBS path.
  • CSS
    • Cluster Name: Click . In the displayed dialog box, select a CSS cluster.
    • Index: name of the CSS index.
  • DLI
    • Connection Name: Click . In the displayed dialog box, select a DLI data connection.
    • Database: Click . In the displayed dialog box, select a DLI database.
    • Table Name: Click . In the displayed dialog box, select a DLI table.
OK
Click OK to save the parameter settings.
Cancel
Click Cancel to cancel the parameter settings.
Edit
Click to modify the parameter settings. After the modification, save the settings.
Delete
Click to delete the parameter settings.
View Details
Click to view details about the table created based on the input lineage.
Output
Add
  • DWS
  • OBS
  • CSS
    • Index: Enter a CSS index name.
  • DLI
OK
Cancel
Edit
Delete
Table Details
Click to view details about the table created based on the output lineage.
