- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
Show all
By default, an Elastic Cloud Server (ECS) is configured with two external domain name system (DNS) servers.
# Generated by NetworkManager search openstacklocal nameserver 114.114.114.114 nameserver 114.114.115.115
If the ECS you will use does not have an elastic IP address (EIP) or you do not want to use an EIP to transmit the traffic load generated during the use of AEI_Register.sh and fisclient programs, add a DNS server in configuration file /etc/resolv.conf.
XXX.XXX.XXX.XXX is the IP address of the DNS server.
# Generated by NetworkManager search openstacklocal nameserver XXX.XXX.XXX.XXX nameserver 114.114.114.114 nameserver 114.114.115.115
- The new DNS server address must be placed above all the existing DNS server addresses.
- The DNS configuration takes effect immediately after modifications to the /etc/resolv.conf file are saved.
Modifications to the /etc/resolv.conf file become invalid after the ECS restarts. In this case, you need to reconfigure the file. If you do not want to reconfigure the file each time after restarting the ECS, perform the following steps to modify the subnet information of the Virtual Private Cloud (VPC) to which the ECS belongs and add DNS server addresses to the subnet to which the ECS belongs.
- Log in to the ECS console.
- In the navigation tree of the ECS console, choose Elastic Cloud Server.
- On the ECS details page, click the NICs tab. Expand details of a chosen NIC and view the name of the subnet to which the ECS belongs.
- On the ECS details page, click the VPC name or ID.
The Network Console is then launched.
- In the right pane of the Network Console, click the VPC name or ID.
A page with details of the VPC is then displayed.
- Choose Subnets from the left navigation bar and click the subnet name or ID in the subnet list to access the VPC subnet page.
- On the subnet details page, click Modify next to DNS Server Address in the Gateway and DNS Information area.
- Enter the IP address of the DNS server in Edit DNS Server Address and click OK.
- Restart the ECS and check that the /etc/resolv.conf file contains the new DNS server address which is placed in the front of other DNS server addresses.
# Generated by NetworkManager search openstacklocal nameserver XXX.XXX.XXX.XXX nameserver 114.114.115.115
Modifying the subnet information of a VPC affects all ECSs in this subnet.
