- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
The enterprise project is a cloud resource management mode. Enterprise Management provides comprehensive management for cloud-based resources, personnel, permissions, and finance. Different from common management consoles that feature independent control and configuration of cloud products, the Enterprise Management console is oriented to resource management, helping enterprises manage cloud-based resources, personnel, permissions, and finance in a hierarchical manner, such as management of companies, departments, and projects.
Users who have enabled Enterprise Management can use it to manage cloud service resources on HUAWEI CLOUD.
Binding an Enterprise Project
When creating a DIS stream, you can select an enterprise project for the stream to associate the stream with the enterprise project. For details, see Step 1: Creating a DIS Stream. The Enterprise Project drop-down list displays the projects you created. In addition, the system has a built-in enterprise project (default). If you do not select an enterprise project, the default project is used.
During stream creation, if the stream is successfully bound to an enterprise project, the stream is successfully created. If the binding fails, the system sends an alarm and the stream fails to be created.
After you delete a DIS stream, the association between the stream and its enterprise project is automatically deleted.
Viewing Enterprise Projects
After a stream is created, you can view the enterprise projects associated with the stream on the stream list and basic stream information page. You can query only the stream resources of the project on which you have the access permission.
In the Enterprise Project column of the Streams page, view enterprise projects to which streams belong.
On the Streams page, click a stream name. In the stream details area, view the enterprise project associated with the stream. Click the enterprise project name to view and edit it on the Enterprise Management console.
When querying the resource list of a specified project on the Enterprise Management console, you can also query the DIS resources.
Searching for Stream by Enterprise Project
Log in to the DIS console and choose Stream Management. In the drop-down list above the streams, select a required project name to view all streams associated with the project.
Migrating Streams into or out of Enterprise Projects
One DIS stream can be associated with only one enterprise project. After a stream is created, you can migrate it from its current enterprise project to another one on the Enterprise Management console, or migrate the stream from another enterprise project to a specified enterprise project. After the migration, the stream is associated with the new enterprise project. The association between them the stream and the original enterprise project is automatically released. For details, see Resource Management > Managing Enterprise Project Resources in the Enterprise Management User Guide.
