Configuring the DIS Logstash Plugin
DIS Logstash Plugins consist of the Input and Output plugins. This section describes the configuration items of the plugins.
Configuring DIS Logstash Input
The configuration template (used to download data from a DIS stream to a local file) is as follows:
input
   dis {
        streams => ["YOUR_DIS_STREAM_NAME"]
        endpoint => "https://dis.${region}.myhuaweicloud.com"
        ak => "YOUR_ACCESS_KEY_ID"
        sk => "YOUR_SECRET_KEY_ID"
        region => "YOUR_Region"
        project_id => "YOUR_PROJECT_ID"
        group_id => "YOUR_APP_ID"
        client_id => "YOUR_CLIENT_ID"
        auto_offset_reset => "earliest"
output
    file {
       path => ["/tmp/test.log"]
Table 1 DIS Logstash Input configuration parameters
Mandatory
Default Value
stream
Yes
DIS stream name.
The entered DIS stream name must be the same as the stream name specified when you are creating a DIS stream on the DIS console.
ak
Yes
User's AK.
For details about how to obtain an AK, see Checking Authentication Information.
sk
Yes
User's SK.
For details about how to obtain an SK, see Checking Authentication Information.
region
Yes
Region in which DIS is located.
project_id
Yes
Project ID specific to your region.
For details about how to obtain a project ID, see Checking Authentication Information.
client_id
No
Client ID, which identifies a consumer in a consumer group.
If multiple pipelines or Logstash instances are started for consumption, set this parameter to different values. For example, the value of instance 1 is client1, and the value of instance 2 is client2.
logstash
endpoint
Yes
Data API address of the region where DIS resides.
group_id
Yes
DIS App name, used to identify a consumer group. The value can be any character string.
auto_offset_reset
No
Position where data starts to be consumed from the stream. The options are as follows:
earliest: Data is consumed from the earliest one.
latest: Data is consumed from the latest one.
latest
Configuring DIS Logstash Output
The configuration template (used to read data from a local file and upload it to a DIS stream) is as follows:
input
   file {
       type => "log4j"
       start_position => "beginning"
output
    dis {
        stream => ["YOUR_DIS_STREAM_NAME"]
Table 2 DIS Logstash Output configuration parameters
Mandatory
Default Value
stream
Yes
DIS stream name.
ak
Yes
User's AK.
sk
Yes
User's SK.
region
Yes
project_id
Yes
body_compress_enabled
No
Specifies whether to enable data compression.
No
body_compress_type
No
Data compression type. The following compression algorithms are supported:
lz4: a compression algorithm with a fast compression speed and high compression efficiency
snappy: a compression algorithm with a high compression speed and a reasonable compression rate, not for achieving maximum compression or being compatible with other compression formats
zstd: a new lossless compression algorithm with a fast compression speed and high compression ratio
lz4
