Viewing Events
This section describes how to search for events that occur in a stream or dump task.
- In the navigation tree, choose Event Management > Events. All events are displayed by default.
 - Select different filter criteria from the drop-down list in the upper right corner of the event list to search for events. Events can be filtered based on the event level or event source.
- In the Event Levels drop-down list, select All, Normal, or Warning
 - In the Event source drop-down list, select Event source. In the search box, enter a stream name or a dump task name, for example, demo.
 - Click
. The filtered event query results are displayed. - Click
 on the right of Event and select an event name, for example, Dump task restored to filter the corresponding events.
   Parent topic: Notifying Events
