- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
Managing Stream Tags
A tag is an identifier of a stream. Adding tags to streams can help you identify and manage your stream resources.
You can add a maximum of 10 tags to a stream when creating the stream or add them on the details page of the created stream.
A tag consists of a tag key and a tag value. Table 1 describes the rules for naming the tag key and value.
Parameter |
Rule |
Example |
Key |
A tag key cannot be left blank. A stream can have only one tag key. You can enter a maximum of 36 characters for Key. The value of Key cannot start or end with a space and cannot contain any of the following characters: is equal to (=), asterisk (*), is less than (<), is greater than (>), backslash (\), comma (,), delimiter (|), and slash (/). |
Organization |
Tag value |
The value can be null. You can enter a maximum of 43 characters for Key. The value of Key cannot start or end with a space and cannot contain any of the following characters: is equal to (=), asterisk (*), is less than (<), is greater than (>), backslash (\), comma (,), delimiter (|), and slash (/). |
Apache |
Adding a Tag to a Stream
- On the management console, choose Service List > Analytics > Data Ingestion Service.
- On the DIS management console, click Buy Stream.
- On the Advanced Settings tab page, select Configure.
Enter the key and value of a tag to be added.
You can add a maximum of 10 tags to the stream and use intersections of tags to search for the target stream.
Searching for a Target Stream
- Choose EI Enterprise Intelligent > Data Ingestion Service.
- In the navigation tree, choose Ingestion Management > Stream Management. In the upper right corner of the page, click Search by Tag.
- Enter the tag key and value of the stream you are searching for.
You can select a tag key or tag value from its drop-down list. When the tag key or tag value is exactly matched, the system can automatically locate the target stream. If you enter multiple tags, their intersections are used to search for the stream.
- Click Search.
The system searches for the target stream by tag key or value.
Managing Tags
- In the navigation tree, choose Ingestion Management > Stream Management. Click a stream to which the tags to be managed belong to.
The stream details page is displayed.
- Click the Tags tab and add, deleted, modify, and view tags.
- View
On the Tags tab page, you can view details about tags of the stream, including the number of tags and the key and value of each tag.
- Add
Click Add Tag in the upper left corner. In the displayed Add Tag dialog box, enter the key and value of the tag to be added, and click OK.
- Modify
In the Operation column of the tag, click Edit. In the displayed Edit Tag page, enter new tag key and value and click OK.
- Delete
In the Operation column of the tag, click Delete. After confirmation, click OK in the displayed page for deleting a tag.
- View
