- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
On this page
Show all
Changing a Source Data Type
The source data schema is required for data conversion of a specific dump task in a stream. If it is incorrectly configured, data conversion fails and the dump task is abnormal. You can configure the source data schema when creating a stream or when creating a dump task. You can modify the configured source data schema on the stream details page.
- Use the account to log in to the DIS console.
- Click
in the upper left corner of the page and select a region and project.
- In the navigation tree on the left, choose Stream Management.
- Click the name of a stream to access its details page.
- Click
next to Source Data Type and select a desired source data type from the drop-down list. Alternatively, in the Operation column of the stream for which you want to change its source data type, choose More > Change Source Data Type. In the displayed dialog box, change the source data type.
- You can change the source data type for a stream whose Source Data Type is BLOB, JSON, or CSV only when the stream has no dump tasks.
- After you change the source data type of a stream for which you have configured source data schema, the existing source data schema will become invalid and cannot be recovered. You need to reconfigure the source data schema for the stream.
Parent topic: Managing DIS Streams
