Preparing a DIS Spark Streaming Environment
Preparing a DIS Application Development Environment
- Set up DIS application development environments by following the procedure in Step 1: Creating a DIS Stream.
 - Install Maven. Configure a local repository address.
 - Install scala-sdk.
Configuring the DIS Spark Streaming Dependency
The DIS Spark Streaming dependency can be introduced to the project through the following configuration:
<dependency>
    <groupId>com.cloud.dis</groupId>
    <artifactId>cloud-dis-spark-streaming_2.11</artifactId>
    <version>1.2.1</version>
    <scope>compile</scope>
</dependency>
 Checking Authentication Information
- AK/SK file
Access Key ID/Secret Access Key (AK/SK) files are created by the Identity and Access Management (IAM) service to authenticate calls to application programming interfaces (APIs) on the cloud. To obtain AK/SK, choose .
 - Project ID
A project is a group of tenant resources. A tenant can have multiple projects, one for each region. Each region has a unique Project ID. To view the project IDs of different regions, choose .
