Stopping DIS Agent
Stopping DIS Agent on a Linux Server
- Start PuTTY and log in to the server on which logs reside.
 - Run the following command to navigate to the DIS Agent installation directory:
cd /opt/dis-agent-X.X.X/
 - Run the following script to stop the DIS Agent:
bash bin/stop-dis-agent.sh
     Run the bash script to stop the DIS Agent. Running another script, such as sh or ./ may fail to stop the DIS Agent.
If information similar to the following appears, the DIS Agent is stopping. xxxxx indicates the process ID.
Stopping Agent [xxxxx].....
If information similar to the following appears, the DIS Agent has stopped:
Stopping Agent [xxxxx]............. Successfully.
To forcibly stop the DIS Agent process, perform the following steps:
Stopping DIS Agent on a Windows Server
- Press Ctrl+C on the CMD terminal. The following information appears:
[INFO ] (Agent STOPPING) com.bigdata.dis.agent.Agent Agent: Shutting down...
 - When the following information appears, it indicates that the DIS Agent has stopped. Enter Y and then press Enter to exit.
Terminate batch job (Y/N)?
