- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
Show all
DIS Agent Overview
DIS Agent is a client-side program provided by the Data Ingestion Service (DIS) to fulfill the following tasks:
Monitor text files continuously, collect incremental data in real time, parse the data by delimiter and upload it to DIS streams. The source data type of a stream can be BLOB, JSON, and CSV.
Figure 1 depicts the process for installing the DIS agent.
