- What's New
- Getting Started
User Guide
- IAM Permissions Management
- Getting Started
- Managing DIS Streams
Using DIS
- Checking and Configuring DNS Information
- Uploading Data by Using Agent
- Using DIS Flume Plugin to Upload and Download Data
- Using a DIS Logstash Plugin to Upload and Download Data
- Using Kafka Adapter to Upload and Download Data
- Using SparkStreaming SDK to Download Data
- Using a DIS Flink Connector to Upload and Download Data
- Managing a Dump Task
- Managing Enterprise Projects
- Notifying Events
- Monitoring
- Best Practices
SDK Reference
- Overview
- Related Resources
- Enabling DIS
- Creating a DIS Stream
- Obtaining Authentication Information
Getting Started with SDK
Using the Java SDK
- Preparing the Environment
- Configuring a Sample Project
- Initializing a DIS SDK Client Instance
- Creating a Stream
- Creating a Dump Task
- Updating a Dump Task
- Deleting a Dump Task
- Querying a Dump Task List
- Querying Dump Details
- Deleting a Stream
- Querying a Stream List
- Querying Stream Details
- Downloading Streaming Data
- Uploading Streaming Data
- Obtaining the Data Cursor
- Creating an Application
- Deleting an Application
- Adding a Checkpoint
- Querying a Checkpoint
- Changing Partition Quantity
Using the Python SDK
- Preparing the Installation Environment
- Creating a Stream
- Deleting a Stream
- Uploading Streaming Data in JSON Format
- Uploading Streaming Data in Protobuf Format
- Viewing Application Details
- Querying an Application List
- Obtaining a Data Cursor
Using the Java SDK
- Error Codes
- Change History
- API Reference
General Questions
- What Is DIS?
- What Is a Partition?
- What Can I Do with DIS?
- What Advantages Does DIS Have?
- Which Modules Do DIS Have?
- How Do I Create a DIS Stream?
- What Is the Difference Between Storing Data into DIS and Dumping Data Elsewhere?
- How Do I Check Software Package Integrity?
- How Do I Send and Retrieve Data Using DIS?
- What Is Data Control?
- Dump Questions
- DIS Agent Questions
General Questions
On this page
Show all
Listing DIS Streams
The Stream Management page displays all DIS streams created. After clicking a stream, you can view the following information about this stream:
- Name/ID: Unique name of the DIS stream to be created. A stream name is 1 to 64 characters long. Only letters, digits, hyphens (-), and underscores (_) are allowed.
- Status: Stream status.
- Stream Type: Common and Advanced.
- Common: Each partition supports a maximum read speed of 2 MB/s and a maximum write speed of 1 MB/s or 1,000 records/s.
- Advanced: Each partition supports a maximum read speed of 10 MB/s and a maximum write speed of 5 MB/s or 2,000 records/s.
- Partitions: The number of partitions into which data records in the newly created DIS stream will be distributed. Multiple partitions of a stream can concurrently transmit data to improve efficiency.
- Source Data Type: BLOB, JSON, and CSV.
- Data Retention (hours): The maximum number of hours for DIS to preserve data. Data will be deleted when the retention period expires. Value range: an integer ranging from 24 to 72. Unit: hour
- Created: Time at which the DIS stream is created. The creation time is in the yyyy/MM/dd HH:mm:ss GMT format. For example, 2017/05/09 08:00:00 GMT+08:00.
- Billing Mode: Only pay-per-use is supported.
- Operation: Supported operations include Change Source Data Type, Delete, and View Dump Task.
Parent topic: Managing DIS Streams
