Updated on 2026-09-11 GMT+08:00
Creating a Secret
When you create a secret on CSMS for secret hosting, the secret value will be stored in the original secret version, which is marked as SYSCURRENT.
Secret value, the detailed content of a secret, is used to verify user identity or authorization during authentication. It can be of various forms, depending on the used authentication mechanism. Typical secret values include:
  • Username and password: A username is the identity of a user, and a password is the key secret value for user identity authentication.
  • Digital certificate: The public key and identity, which are the secret values of a certificate, are used to verify the identity of a user or device.
  • Key pair: The private key, which is the secret value, is used for signature and decryption.
  • Token: A token is a temporary secret value used for identity authentication.
  • Biometric recognition information: Biometric feature data, such as fingerprint, facial recognition, and iris recognition, is the secret value.
  • One-time password (OTP): An OTP generated via SMS, email, or a certain application is the secret value.
  • A maximum of 5,000 secrets can be created on CSMS.
  • A secret can be no larger than 64 KB.
  • By default, the default key csms/default created by CSMS is used as the encryption key of the current secret. You can also create a user-defined symmetric key and use a user-defined encryption key on the KMS console.
  • RDS secrets support MySQL, PostgreSQL, SQLServer, MariaDB, and TaurusDB engines.
  • TaurusDB is supported for TaurusDB secrets.
Creating a Secret
CSMS allows you to create a shared secret or a rotated secret as required.
  1. Log in to the DEW console.
  2. Click in the upper left corner and select a region or project.
  3. In the navigation pane on the left, choose Cloud Secret Management Service > Secrets.
  4. Click Create Secret. Configure parameters in the Create Secret dialog box, as shown in Figure 1. For details about the parameters, see Table 1.
    Figure 1 Creating a secret
    Table 1 Secret parameters
    Type
    Secret type. The default value is Shared secret. You can select Shared secret or Rotated secret. For details, see Overview.
    Secret Name
    Secret name.
    Only letters, digits, periods (.), hyphens (-), and underscores (_) are allowed.
    Enterprise Project
    This parameter is provided for enterprise users. If you are an enterprise user and have created an enterprise project, select the required enterprise project from the drop-down list. The default project is default.
    If you have not enabled enterprise management, this parameter will not be displayed.
    Secure Input
    You can click to enable secure input.
    Once enabled, you cannot view the sensitive information you entered or switch between key values and plaintext. To ensure there are no errors, you need to enter sensitive information twice. If you want to hide the information on the console, configure IAM permission policies.
    Secret Value
    Secret key/value pair or the plaintext secret to be encrypted.
    When entering the secret value, you can click the eye icon to toggle visibility.
    Click to switch to multiple-line/single-line input.
    KMS Encryption Key
    The following modes are supported:
    • Select from list: Select this if you want to use the key used or shared by the current account. Select the default key csms/default or a custom key created on KMS.
    • Enter: Enter the ID of the authorized key. Enter an encryption key if an authorized key is used. Only symmetric algorithm key IDs are supported. Do not enter an asymmetric key ID.
    • CSMS encrypts secret values using the encryption key provided by KMS. When you use the KMS encryption function, KMS creates a default key csms/default for you to use.
    • For details about how to create a custom key on KMS, see Creating a Key.
    • After a grant is created, you can switch to the manual input mode, and enter the key ID to use the granted key for encryption. For details, see Creating a Grant for a Custom Key.
    Advanced settings
    • Associated events
      Select an associated event for the secret. You can check information such as secret rotation and version expiration.
    • Description
      Description of a secret
    • Tag
      You can add tags to a secret as you need.
      You can add at most 20 tags to a secret.
  5. Click Next. You cannot select a rotation period for common secrets. Go to the next step.
  6. Click Next and confirm the creation information.
  7. Click OK. In the secret list, you can view the created secrets. The default status of a secret is Enabled.
  4. Click Create Secret and set Type to Rotated secret.
    Figure 2 Creating a rotated secret
  5. On the displayed Create Secret page, set the parameters. For details about the parameters, see Table 2.
    Table 2 Parameters for rotated secrets
    Type
    Type of the secret to be rotated. The following secrets are supported:
    • RDS secret
    • TaurusDB secret
    • APIG secret
    • GaussDB secret
    • DCS Redis secret
    • DMS Kafka secret
    • DMS RabbitMQ secret
    • DMS RocketMQ secret
    Secret Name
    Secret name
    Enterprise Project
    Database
    This parameter is mandatory if Type is set to RDS rotated secret.
    RDS secrets support MySQL, PostgreSQL, SQLServer, MariaDB, and TaurusDB databases.
    RDS DB Instance
    Select the RDS instance corresponding to the target database type.
    TaurusDB Instance
    If Type is set to Rotated secret > TaurusDB secret, select a TaurusDB instance as needed.
    Click View TaurusDB Instances. You can buy a TaurusDB instance on the displayed console.
    GaussDB Instance
    If Type is set to Rotated secret > GaussDB secret, select a GaussDB instance as needed.
    Click View GaussDB instances. You can buy a GaussDB instance on the displayed console.
    APIG Instance
    If Type is set to Rotated secret > APIG secret, select an APIG instance as needed.
    After selecting the target instance, you need to set App and APIG Secret Type.
    App
    This parameter is mandatory if Type is set to Rotated secret > APIG secret. You can click View App to go to the APIG console and view the created APIG secret.
    APIG Secret Type
    If Type is set to Rotated secret > APIG secret, select an APIG secret type as needed. The following secret types are supported:
    • Secret: After an app is selected, an app key is automatically generated.
    • AppCode: If this option is selected, you need to select an existing AppCode from the drop-down list. You can also click View AppCode to add an AppCode on the displayed console.
    Secret Value
    Account name and password to be encrypted.
    • If Single account is selected, you need to enter an available database account.
    • If Dual account is selected, after you enter an available database account, a cloned account with the same permissions will be created. Select I understand the risks.
      If Type is set to Rotated secret > DMS Kafka secret, you need to manually create a clone account that has the same topic access permissions and request throttling policies as the primary account.
    For details, see Rotation Policy.
    KMS Encryption Key
    Advanced settings
    • Associated events
    • Description
    • Tag
  6. Click Next. Enable Automatic Rotation, set the rotation period and function, select I understand the risks, and click Next.
    You can select an existing period or set a custom one.
    Figure 3 Enabling automatic rotation
    After automatic rotation is enabled, if no agency is created for the current user, a dialog box is displayed, showing the permission name and items. Click OK to complete the authorization.
    Table 3 Rotation setting parameters
    Example
    Automatic Rotation
    Choose whether to enable automatic secret rotation.
    Enabled
    Set Rotation Period
    Select an existing period or set a custom one.
    6 hours
    Rotation function
    Create or use an existing rotation function in FunctionGraph to rotate secret values.
    CloudSecretManager-kl15
  7. Click Next. Confirm the secret information and click OK.
Related Operations
You can also perform the following operations on secrets.
Viewing Secret Details
This section describes how to check secret names, statuses, and creation time on the CSMS console. The secret status can be Enabled or Pending deletion.
  1. In the navigation pane on the left, choose Cloud Secret Management Service > Secrets.
  2. Check the secret list. For more information, see Table 4.
    Figure 4 Secret list
    Table 4 Secret list parameters
    Secret Name/ID
    Secret name and ID
    Status
    Status of a secret. The value can be Enabled or Pending deletion.
    Type
    Secret type, including shared secret, RDS DB secret, and TaurusDB secret.
    Associated events
    Bound event notification when the secret was created.
    Creation Time
    Time when the secret is created
    Last Accessed
    Last time when the secret was accessed.
    Enterprise Project
    Enterprise project that the secret is to be bound to
  3. Click a secret to view its details, as shown in Figure 5.
    • You can click Refresh to refresh secret information.
    • In the secret details area, you can modify the encryption key, description, enterprise project, and associated events.
      Figure 5 Secret details
Downloading a Secret Backup
To download a secret to a local PC for backup, perform the following steps:
  2. Locate the target secret in the list and click Download Backup in the Operation column.
    The secret file will be downloaded to the local host and named SecretName.secretbackup.
Restoring a Secret from a Backup
DEW allows you to restore a secret from backup. After a secret is restored from backup, the secret ID will be changed.
Only secret backup files smaller than 5 MB can be uploaded.
  2. Click Restore Secret, select a backup file, and click OK.
    Figure 6 Restoring a secret backup
Deleting a Secret
Before deleting a secret, ensure that it is not in use and will not be used. If you delete a secret, applications relying on it cannot retrieve its value, which can disrupt your services. For a rotated secret, automatic rotation can trigger the last access timestamp. You are advised to disable rotation and monitor the secret's access logs for a period of time before deleting it.
  • A secret will not be deleted until its scheduled deletion period expires. You can set the period to a value within the range 7 to 30 days. Before the specified deletion date, you can cancel the deletion if you want to use the secret. If the scheduled deletion period of a secret expires, the secret will be deleted and cannot be restored.
  • For details about the billing information about a secret to be deleted, see Are Credentials Scheduled to Be Deleted Billed?
  • If you delete a secret immediately, you can restore it using the secret backup that you have downloaded in advance. Exercise caution when performing this operation.
  2. Locate the target secret and click Delete.
  3. In the displayed dialog box, click Schedule deletion or Delete now. If you select Schedule deletion, set Waiting Period (7 to 30 days).
    Figure 7 Deleting a secret
  4. Enter DELETE in the confirmation dialog box if deletion verification is disabled and click OK.
    If you have enabled deletion verification, select a verification mode, click Get Code, enter the code, and click OK.
FAQ
For more FAQs about secret creation, see CSMS FAQ.
