Updated on 2026-09-11 GMT+08:00
Overview
KMS allows you to manage the lifecycle of keys and encrypt and decrypt data.
The core key components in KMS include customer master keys (CMKs) and data encryption keys (DEKs). CMK, the top-level key of the user, is used to encrypt and decrypt sensitive data and generate DEKs. DEK, the second-level key in the envelope encryption process, is used to encrypt services and is protected by CMKs.
Key Usage
Keys created in KMS can be used for server-side encryption of cloud services and application-integrated KMS encryption.
  • Server-side encryption of cloud services: KMS keys are integrated with cloud services such as OBS, EVS, and RDS to implement transparent encryption of static data and protect data assets on the cloud. For details, see Interacting with Huawei Cloud Services.
  • Application-integrated KMS encryption: KMS OpenAPIs/SDKs are called to implement cryptographic functions such as data encryption and decryption, digital signature, and signature verification in applications. For details, see Working with User Applications.
Key Types
KMS provides default keys, custom keys, and external keys to meet security and compliance requirements in different service scenarios. The following table lists the details.
Table 1 Key types
Key Type
Function
Algorithm Type
Key Specifications
Default key
Used by cloud services for server-side encryption.
For details, see Cloud Services Integrated with KMS.
Only data encryption and decryption are supported.
Symmetric keys: AES
AES_256 (AES-256-GCM authentication encryption)
Default keys are created and managed by KMS. The alias of a default key ends with /default.
Custom key
  • Created by users to build application-layer cryptographic solutions. For example, you can create a master key using the AES algorithm for custom data encryption and decryption, and create a master key using the RSA or ECC algorithm for digital signature calculation and verification.
  • Used by cloud services for server-side encryption.
Data encryption, decryption, and digital signature are supported.
  • Symmetric keys: AES
  • Asymmetric keys: RSA, ECC, ML-DSA, SECP256K1, ED25519
  • Digest keys: SHA
To enable the ML-DSA algorithm, submit a service ticket.
  • Symmetric keys: AES_256 (AES-256-GCM authentication encryption mode)
  • Summary keys: HMAC_256, HMAC_384, and HMAC_512
  • Asymmetric keys: RSA_2048, RSA_3072, RSA_4096, EC_P256, EC_P384, ML-DSA-44, ML-DSA-65, ML-DSA-87, SECP256K1, ED25519
For details, see Key Algorithms and Specifications Supported by KMS.
You can create a key and manage its lifecycle on KMS, which generates key materials.
External key
  • Created by users to build application-layer cryptographic solutions. For example, you can create a master key using the AES algorithm for custom data encryption and decryption.
  • Asymmetric keys: RSA, ECC, ED25519
  • Asymmetric keys: RSA_2048, RSA_3072, RSA_4096, EC_P256, EC_P384, ED25519
You can create a key and manage its lifecycle on KMS. You need to import the key materials.
Table 2 Key algorithms supported by KMS
Key Type
Algorithm Type
Key Specifications
Symmetric key
AES
AES symmetric key
  • Data encryption and decryption
  • DEK encryption and decryption
    You can encrypt and decrypt a small amount of data using the online tool on the console.
    You need to call APIs to encrypt and decrypt a large amount of data.
Digest key
SHA
  • HMAC_256
  • HMAC_384
  • HMAC_512
Digest key
  • Data tampering prevention
  • Data integrity verification
Asymmetric key
RSA
  • RSA_2048
  • RSA_3072
  • RSA_4096
RSA asymmetric key
  • Digital signature and signature verification
    Asymmetric keys are applicable to signature and signature verification scenarios. Asymmetric keys are not efficient enough for data encryption. Symmetric keys are suitable for encrypting and decrypting data.
Asymmetric key
ECC
  • EC_P256
  • EC_P384
Elliptic curve recommended by NIST
Asymmetric key
ED25519
ED25519
Elliptic curve in Edwards form
Asymmetric key
ML-DSA
  • ML-DSA-44
  • ML-DSA-65
  • ML-DSA-87
Modular lattice digital signature algorithm
Quantum-resistant digital signature and signature verification
Asymmetric key
SECP256K1
SECP256K1
Elliptic curve cryptography (ECC)
Table 3 describes the encryption and decryption algorithms supported for user-imported keys.
Table 3 Key wrapping algorithms
Algorithm
Configuration
RSAES_OAEP_SHA_256
RSA algorithm that uses OAEP and has the SHA-256 hash function
Select an algorithm based on your HSM functions.
If the HSMs support the RSAES_OAEP_SHA_256 algorithm, use RSAES_OAEP_SHA_256 to encrypt key materials.
KMS-Created and Imported Key Materials
A key contains key metadata (key ID, key name, description, key status, and creation date) and key materials used for data encryption and decryption.
  • When you create a custom key on the KMS console, KMS automatically generates a key material for the key.
  • If you want to use your own key material, set Management Type to Platform-managed when you create a custom key on KMS, and import the key material.
Table 4 Differences between imported key materials and key materials generated by KMS
Key Material Source
Difference
KMS
  • A key material cannot be manually reset.
  • Only symmetric keys can be rotated.
  • You cannot set the expiration time for the key material.
User import
  • You can manually reset a key material, but cannot delete the custom key or its metadata.
  • When importing a key material, you can set its expiration time. After the key material expires, KMS automatically resets the key material within 24 hours, but does not reset the custom key or its metadata.
    You are advised to securely back up the key material in your local key management infrastructure so that you can re-import the key material if it expires or is reset by mistake.
    Keys using the RSA_2048, RSA_3072, RSA_4096, EC_P256, and EC_P384 algorithms are permanently valid. Their key materials cannot be manually reset, and their expiration time cannot be set.
Principles of Key Regions
KMS allows you to use keys across regions. Each pair of CMK and replica key shares the same key materials, so that data encrypted in a region can be decrypted in another.
You can manage keys of multiple regions, edit replica key alias, enable, disable, tag, and authorize replica keys. You can also encrypt and decrypt replica keys online. The rotation of replica keys cannot be configured independently, which is synchronized with CMK rotation.
For details about how to create a replica key, see Creating a Replica Key for a Custom Key.
Figure 1 shows the principle of multi-region keys.
Figure 1 Multi-region keys
Table 5 Application scenarios
Application Scenario
Disaster recovery (DR)
If resources in the region where a key is created are frozen due to arrears or data cannot be decrypted due to exceptions, replica keys in another region can be used to ensure service continuity.
Cross-region signature verification
If services are deployed in different regions, you can use multi-region keys to verify and decrypt signatures, improving service interconnection efficiency.
Appendix: Components of a Key
A key consists of a key identifier, metadata, and a key material.
  • Key identifier: It uniquely identifies and references a key on the console, in an API, or in a policy. KMS supports the following identifiers:
    • Key ID: A 36-byte string that matches the ^[0-9a-z]{8}-[0-9a-z]{4}-[0-9a-z]{4}-[0-9a-z]{4}-[0-9a-z]{12}$ regular expression. Example: 0d0466b0-e727-4d9c-b35d-f84bb474a37f
    • Alias: The identifier of a key. The value starts with alias/. Example: alias/4555
    • URN: Each alias automatically matches a unique URN. Example: kms:eu-de-ring0:3ba44455500dd43127:alias:4555
  • Metadata: Information that describes the attributes of a key, such as the key ID, creation date, key status (enabled or disabled), and key usage (encryption/decryption or signing/verification).
  • Key material: Binary data used for cryptographic operations, including encryption, decryption, and signing. KMS supports the following material sources:
    • Huawei Cloud KMS: You can use KMS to generate key materials.
    • External: You can generate a key material locally and import it to KMS.
